http://docs.hotpoint.eu/_doc/F085253_HUI612_P_MANUAL.pdf
Do you know for certain that the motherboard has failed? What evidence apart from the none of the hobs or controls work?
I did a quick google of reviews of this freestanding hob/oven and they were good. It makes me wonder if the controls are locked or the hob needs a reset after power up.
And it would be very helpful to know what size mcb supplies the oven and hob - you have not mentioned this yet. We need to know because the hob peak power could be 7.2kW and the oven about 2kW making a total of 9ish kW. (Of interest - the peak power of the induction hob can be reduced - see page 10 Setting the Power Management:
The cooktop maximum power limit is 7200W. This power limit can be reduced by the user to 2800W, 3500W or 6000W.
Is it the cooker in the reference above?
If it is then after power is applied or restored the controls might locked. See page 10 'switching on the hob'. If this restores functionality the hob needs to carry out an ambient light calibration - see page 10 'Initial Light Conditions' - if there is too much ambient light this calibration process can fail until the ambient light is reduced. On page 11 it mentions the 'Control Panel Lock' feature - how to activate and de-activate it. It says:
All the keys on the cooking zone selection wil be locked if :the cooktop is off,, if the Control Panel Lock is activated or if an error on a cooktop occurs..
On page 12 on 'Switching off the hob':
Press the button to switch off the appliance - do not rely solely on the pan sensor. If the control panel lock has been activated, the controls will continue to be locked even after the hob is switched on again. In order to switch the hob on again, you must first remove the lock function.
and on Overheating protection:
If the electronic elements overheat, the number signalizing the power level starts flashing, and the letter “c” appears on the display. When the temperature has reached a suitable level, this message disappears and the hob may be used again.
Finally Hotpoint advise on Errors and Alarms:
When an error is detected, the whole appliance or the heater/s are switched off, a beep sounds (only if one or more heaters are active) and all displays show a ‘F’ letter and the error code (an index number or a letter) alternately. If the problem does not disappear by itself, please contact the Technical Service.
Hotpoint Service We are the largest service team in the country offering you access to 400 skilled telephone advisors and 1100 fully qualified engineers on call to ensure you receive fast, reliable, local service. UK:
08448 224 224
