Full set of drivers £4.99 | Page 2 | on ElectriciansForums
Discuss Full set of drivers £4.99 in the Electrical Tools and Products area at ElectriciansForums.net
the aldi multitool is good as well. they do 240V and 10.8V when you can find them in.
Yes Tel got one of those in 10.8v as on site use it only occasionally and does its job I think the moral of the thread is if you only use things now and again some of these items are worth it however for everyday used tools (and for tool tarts like Pete) its best to go for good quality and paying a bit more.
For ducting. I usually use it for 100mm fan vents.
Plastic flexi usually goes through as does the slim wall solid duct supplied with some fans. Thick wall rigid duct or metal flexi duct usually needs a slightly bigger cut though.
or a 4lb.lump hammer. :mad:
i bought that aldi set of core drills 2 years ago for a job. cored out fan in a bathroom. then client changed his mind and went for an attic fan from ceiling. set is still in box, virgin.
Reply to Full set of drivers £4.99 in the Electrical Tools and Products area at ElectriciansForums.net
I would say it is more about the bits than the torque of the drill. I use high quality Fisch auger bits for drilling out mortices and peg holes...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
