full test or not? | Page 2 | on ElectriciansForums
Discuss full test or not? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
nick611
your right krishcanag if the installation has a current cert then why should you do another
I think you misunderstood what I said, the installation does get a full inspection and test, just that some of the testing is carried out during the change, and parts after.
I would only do both a full EICR and full test if the customer requested both documents, otherwise it still gets a full I&T but just the EIC with the schedules submitted.
Like the other posters have said, I would not rely on previous documentation.
Thanks spark68
In this case it was all done, and so I just done feel the need to repeat stuff for no good reason but copy out, but I think in future I might follow your route, but sometimes the client and even I would need to be sure its a case of only CU change and I believe the IR test is a great way to confirm if a CU change is enough.
cheers
krish
I was under the impression this was a 1 off and as you claim to have the 16th how did you sigh up to a part P scheme then?
Reply to full test or not? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I will offer some initial thoughts. A workplace so the EAWR 1989 applies, it is statutory and carries legal consequence drawing its authority for...
