Fuse board upgrade price. | Page 3 | on ElectriciansForums
Discuss Fuse board upgrade price. in the UK Electrical Forum area at ElectriciansForums.net
You are paying too much for your materials and since when has changing a ccu been a two man job? What does the 2nd bloke do?
Edit; Also a full day??
I am being a bit disingenuous.
Firstly - I don't do domestic.
Secondly - I would only install premium manufacturers.
Lastly - I do not send anyone out alone for safety reasons and all quoted works are quoted as at least one days work.
I know this is silly to most hence I said I was being disingenuous.
Fair enough, I would expect to change a ccu in around 2 hours, maybe 3 if it was a Mantel unit as them Amd 3 Skeletons are awkward. We use Wylex or Crabtree.
That's some going, surely you don't mean with full and proper testing in that timescale ?!
As a result of doing K&Bs for about 18 years i've changed literally hundreds of CCUs so im pretty quick at them but no i was talking about just changing a CCU, but as i would have carried out a full EICR before doing the change a retest after is not going to take long is it?
Sorry Bill, K&Bs ?? It's been a long day ! Yeah just doing a board change without any testing I'd say around 3 hours - that's doing it nice and neat mind. But my usual way is to do all the circuit tests while disconnected after removal of the old board, and IMO to do all the testing and board properly is a full - and sometimes a long days work.
ÂŁ300? Do you eat fresh air for breakfast, dinner and tea and live in a cardboard box??
For breakfast I have a bowl of cornflakes and two slices of toast except for Saturdays when I usually have two crispy bacon rolls with large dollops of Heinz tomato sauce. Dinner during the week is usually pre-packed sandwiches or something out the chippy. My meals when I get in from work are varied. But I have steak with all the trimmings and a king prawn stir-fry once a week. On Friday nights, I always order a curry from my local Indian take-away. I usually have my Sunday roast at the local carvery.
I live in a nice two-bedroom semi with well-kept front and back gardens. The house has a driveway for my van and my car. Not bad for a "tramp", eh?
I trust that your curiosity regarding my diet and living accommodation is now satisfied and that you'll won't ask me any more inane questions.
Get real, you’ll spend that much on materials of yours fitting anything halfway decent!
I think it's you who needs a reality check. If you're paying ÂŁ300-ÂŁ500 for the materials needed for a consumer unit upgrade, then either you are being taken for a mug, or have money to burn. Do you light your cigars with ÂŁ20 or ÂŁ50 notes?
Your statement makes no sense at all. The clear implication is that if I charge between ÂŁ300-ÂŁ500 for a consumer unit upgrade I will make nothing on my labour because the amount I am charging will be consumed entirely by the cost of the materials. Oh really? Is that so? I think not.
One need not look too far to find a fully-loaded 10-way dual RCD Hager consumer unit for less than ÂŁ90.00. A metre of 25mm tails and a metre of 16mm 6491X will cost me just under ÂŁ5.50 maximum. A consumer unit tails kit I can get for just over ÂŁ2.00. A pair of single-pole service connector blocks, if I need them, cost just under ÂŁ5.30. For an outlay of barely over ÂŁ100, I have all the main materials that I need to do the job. Ergo I make ÂŁ200.00 from the job, ÂŁ220.00 if I install a 10-way Schneider Easy 9 dual RCD board instead of a Hager. Maybe you'll now try to argue that Hager and Schneider aren't "halfway decent" brands? Knock yourself out.
£200 for a days work? He’s supposed to be an electrician not a bin-man/tramp!!
In your previous post you incorrectly asserted that I would "spend that much on materials of yours fitting anything halfway decent". This is the post of mine of that you were referring to:
ÂŁ300 would be typical if I've done a recent EICR and there are no other issues other than a lack of RCD protection. ÂŁ500 would be typical if I have to do an EICR prior a board upgrade. Obviously the price would be higher still if issues were discovered during the EICR and taken into account as additional work, or if RCBOs were being installed.
I can only assume that you didn't parse my post correctly, in which case I suggest that in future you spend more time reading and thinking before jumping to incorrect conclusions and making disparaging remarks. I do a lot of EICRs and the former scenario is often the case. Most of the consumer unit upgrades that I do are remedial works arising from EICRs that I have carried-out. As the testing has already been done, I am therefore aware if any faults exist. If so, they are remedied prior to the changeover and charged for separately. If there are no issues, the old board is removed, the replacement installed, leaving me just the post-installation testing to do.
You are very badly mistaken indeed if you think that it takes me a full day to remove a board, install a replacement and carry-out post-installation testing. While it would certainly take me a full day to do an EICR and a board changeover, my price would then be around ÂŁ500. Ergo I would earn ÂŁ400 for the day.
If I quote ÂŁ300 for a board changeover that is going to take place * AFTER * I've carried-out an EICR for which I've charged separately, and have determined that there are no issues other than a lack of essential RCD protection, that leaves ÂŁ200 for my labour. Despite having implied in your previous post that I wouldn't be able to make any money for myself if I charge between ÂŁ300-ÂŁ500, you are now contradicting yourself by claiming that I am working for ÂŁ200 a day. For your information, I do not work for ÂŁ200 a day. Understood?
Exactly, ÂŁ200 for a day is a mickey-taking exercise.
The only person taking the ---- here is you. You have made an non-factual statement based on your interpretation of what you think I said rather than what I actually said. Nowhere in this thread did I say that I work for ÂŁ200 a day. The first person who said that was you. Kindly desist from making any further statements about me that have no basis in fact.
Reply to Fuse board upgrade price. in the UK Electrical Forum area at ElectriciansForums.net
For a TN system neutral is deemed at earth potential.
In the picture of the socket, it looks like one of the neutrals may have been screwed in over the insulation. Therefore, the live may also have...
