Fuse box installed for £150 what!!! | Page 27 | on ElectriciansForums
Discuss Fuse box installed for £150 what!!! in the Business Related area at ElectriciansForums.net
dont know if its only me, but I want proper SCREWS on consumer units back. the ones that screw into some thread, to be used with screwdriver. not some plastic click-lock crap, getting messy after board got opened for testing couple of times :(
while on subject what do you guys prefer dual rcd or high integ ,
obviously different circumstances require different boards but what are your pros and cons on the two
See your point of course, but I have no problem with the plastic click locks, they do the Job quite well in my opinion and are fine in domestic situations.
I'd prefer a board full of individual RCBOs and MCBs mixed actually, but price would dictate whether It was used or not, that would be up to the customer.
i never use high integ , usually just dual rcd
cant see need for high integ unless this should be used to have alarm smokey etc on the unprotected side mcbo/mcb protected
I always try to avoid putting smokes on RCBOs or RCDs, unless the earthing arrangements or installation method forces me to do so.
how long have you been trading ?
I have been trading as a company for 10 years, I am a NICEIC approved contractor and an accredited member of CHAS and EXOR as well and H&E construction safety and I am on the County Council list of approved contractors, My personal grade apart from director is JIB site Technician as well, I am fat over 40 and a miserable Git too, what about you?
only been trading 6months so not with governing body yet various hoops to run and backflip through .
going great all ready got 3 guys working for me never had no work since starting fingers crossed all keeps going well.
have been looking at niceic and select not sure which though.
and am i right in saying part p isnt necessary in scotland
apparently yes not needed up there, all bodies are the same and scammers really, best to go with the cheapest, I expect it will change again soon enough anyhow.
Reply to Fuse box installed for £150 what!!! in the Business Related area at ElectriciansForums.net
Sorry, it’s a proposed installation so neither of those options would be possible until the install is actually complete by which time it would be...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
