fuse connection unit and outdoor lighting low voltage | on ElectriciansForums
Discuss fuse connection unit and outdoor lighting low voltage in the UK Electrical Forum area at ElectriciansForums.net
Uk
Just wondered if it's a no no to run 2 low voltage lights from one FCU
I have wired up sockets and lights to my decking outdoor accessories of course.
From my sockets I have spured of to a RCD FCU from this I have my decking spotlights.
So my question is can I run some LED strip lights to the same FCU I know it will work but is it good practice
Dan
Spurring a RCD FCU from a socket to feed lights is not a problem, providing you downgrade the fuse in the FCU accordingly.
However, it says you've installed sockets on the decking also, and that you've wired the RCD FCU from the sockets that you've just wired as well? Not sure if I'm reading it correct, can you please tell us how you've gone about installing the sockets? Because this is where there could be a problem ...
Mark.
Dan
Of course you can as long as the correct fuse is fitted in the FCU to provide protection
Do the sockets have RCD protection?
Mark.
It shouldn't be a problem how I've installed it as I've come from my CU with SWA cable 2.5mm2 underground to an outdoor rcd socket my CU is also split RCD protection. From the double sockets I have gone to my RCD FCU the breaker I've used is a 16A
Okay, well there's not really a problem. Other than the fact you don't need RCD sockets or FCU if you've installed the new circuit on the RCD side of the CU.
Just a side note, new circuits are also notifiable works.
Reply to fuse connection unit and outdoor lighting low voltage in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
The core tech was never Google. The core technology was Nest, and it’s sound. They got bought up by Google looking for a way in to the home tech...
