Fuse Seals | Page 2 | on ElectriciansForums
Discuss Fuse Seals in the UK Electrical Forum area at ElectriciansForums.net
UK
Newbie Question:
What’s the general consensus with cutting the main fuse seal for a consumer unit change? I’m aware of the requirement to contact the DNO, but just wondering what the done thing is in practical terms?
The logistics of getting the DNO to cut the fuse can be impractical, especially in the current climate.
If you are getting permission, how are you going about it?
But being serious for a minute, if (hypothetically) you were going to pull the DNO fuse you really need to take care if it is anything but a new-ish cut-out in good condition. Even then, you have to make sure it is not on load (so CU(s) already off at main switches) and to wear some PPE like a suitably rated face shield and at the very least something like rigger's gloves to provide some protection against arc-flash injuries to your hand.
If the cut-out looks very old or damaged in any way DO NOT TOUCH IT. In that case your only sane option is to get the DNO folk in to sort it out, as your day is going to end very badly if it shorts out on the incoming side of the cut-out fuse.
[ElectriciansForums.net] Fuse Seals
There are several around my area (including my own, before the meter was replaced), where whoever fitted the seal left so much slack in the wire that the fuse carrier can be pulled out and left hanging with the seal intact.
Reply to Fuse Seals in the UK Electrical Forum area at ElectriciansForums.net
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
I would have to agree with @James to hire an electrician to measure the voltage coming in to the panel. If you have 240vac phase to phase then you...
