Status
Not open for further replies.
A small under counter AEG fridge. Instructions say it is fitted with a 13A fuse in the plug. Also states it must be replaced by a 13A fuse. The fridge is drawing 0.32 amps. A 13A fuse is ridiculously oversized. If having a mcb or RCBO at the CU for just the fridge, a 1.00mm cable can be run on a radial for it.
The instructions do say that a qualified or competent electrician must fit the appliance, so a get out for them. If the electrician say 3A will do then that is that I suppose. Do many ignore these types of instructions and say insert a 3A fuse in the plug? Safer.
You are an electrician aren't you. We work to the regs.
It would be 'electrically incorrect' as it would be marked as a deviation from the regs in a report.
Show me the reg that says local isolation is mandatory? Whatever local isolation is of course. Where should this non-mandatory local isolation be? in a cupboard? Over a worktop? In an adjacent utility room? Under an appliance? Where?
I my point it is not the end of. Only going by regs is not what competent electricians should be doing. Sometimes you have to use the electrical knowledge and training they are given.
Would that be the same knowledge and training that started this thread with the suggestion of 1mm cable and a 3A fuse?
No reg says local isolation is needed.
You should work to your electrical training and knowledge, not be like one of these, rear end covering, moronic, reg followers.
Fair enough if you wish to argue a point but posts like this will see the thread closed.
We are talking about you saying that 1mm is 'electrically correct' for the circuit. Don't try and change the subject because you are wrong and know it mate. Have a look at the table I mentioned in a previous post for the reg.
A sole appliance, on a radial, drawing a third of an amp, on 1.00mm cable on say a 10A mcb is electrically sound and safe. Are you saying it is not?
You are supposed to be electrically trained. To think. Now do not look at table. Tell me where it is electrically not sound or safe? I will be waiting a long time.
Status
