Fuseboard in external meter cupboard | on ElectriciansForums
Discuss Fuseboard in external meter cupboard in the UK Electrical Forum area at ElectriciansForums.net
South West
I was doing a job for a landlord at his tenants house and was aked to have a look at the fuseboard whilst im there to as he wants it changing.
Asked the tenant where the board was and he said it was in the external meter cupboard. I thought he was a bit mistaken by what i meant but it actually was! (photo attached hopefully)
never seen it before, didn't even think it was allowed being DNO property. Where do think i stand when it comes to actually replacing it? am i allowed to change it or does it have to be moved?
that other 2 way DB is supplying to electric showers incase anyone is wondering.
  • [ElectriciansForums.net] Fuseboard in external meter cupboard
this was done on a lot of houses back in 70's-80's. i'd sat that the old wylex was original and the newlec has been added. i'd get all the cables up to the newlec CU and then replace that with a bigger unit.
As above. JFDI. As is above in Tels post. Murdoch may be correct but the chance of anyone actually caring let alone doing something is 2/3rds of three eighths of FA.
Ah right, i always assumed it was all DNO property.
Seems like a crap place to have it.
If it is alright to fit a new board in there then i was going to get rid of that other 2way board and put the shower circuits into a new bigger one.
I used to live in a rented propertie where the board was in the meter cupboard outside. Main RCD switch tripped on night. What a twt that was! I don't think it's against any regs to leave it where it is but my opinion would be to find where the cables go through and pull them back into the house and fit the board there, unless they come out in the shower!
With any luck, all the cables go up the cavity so you could possibly fish them out the other side of the wall (inside) at bit higher up and site the new CU there, just extending the tails to suit.
At least you'll have plenty on the cables so no need for any crimps/wagos to join them out!
The dno like only cutout metering and isolator in meter cupboard,if its in insitu which it is, not a problem,as stated best to move it. Just some advice cu's can be fitted outside provided they are put in additional Ip44 box adjacent meter box.
Reply to Fuseboard in external meter cupboard in the UK Electrical Forum area at ElectriciansForums.net
I would think that if they are apartments, and not something like uni halls with private bedroom and communal facilities, then each one would be...
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
Recommended Sponsor News
Hi everyone,
