Well obv they would say that. ?Don't know why people think this mix and match situation is a recent thing as it has been a requirement for years to follow manufacturers guidance and this wouldn't have included fitted non-compatible devices it really is nothing new.
"People" can do as they wish.As a last resort.
Not a perfect analogy, but we can run with it a bit.
If engines were not repairable, and I had a car which needed an engine, and I couldn't get a new one, and it was a quick and easy job to install a used one I wouldn't rule it out on the grounds that it was used.
In no new car I've ever had have I gone and put a new engine in it, or replaced the tyres just because they weren't new...
These analogies aren't perfect, but the tyre one raises another point. People cavil at the idea of putting s/h tyres on their car, but I'll bet a lot of them buy s/h cars and carry on using the s/h tyres that came with it.
Gut feel says that's more likely to be a problem with new devices than used ones. If you're making fake MCBs why go to the hassle of making fake used ones, given the very much smaller market?"People" can do as they wish.
As a professional and also as a scheme member you're responsible for what you install, with regard to sourcing genuine parts and observing manufacturer recalls etc, eBay etc guarantees none of this and has also been the source of fake MCBs (mere switches with no coil etc)
A compliant solution is sometimes a little effort, thought, and significant expense away.same with mix'n'natching components, yes it can be a little annoying when you know many things will work with vanishingly little real danger, and yes its (yet) another example where the idiots on high think over regulating the compliant guys taking care about what theyre doing will somehow address the bodges of those wilfully ignoring any rules, but a compliant solution is rarely more than a little effort and thought away.
".... so I'll stop trying, and thereby, hopefully, bring conflict and dispute to an end, as I don't want those."
I meant to say.
That board is missing the surge protection module, which adds £30+. (they do offer it in another more expensive listing). I assume the RCBOs are also the type AC ones, which are cheaper than type A, again they don't say.
You've completely missed my point. Your scheme requires that you have tracable QA for what you buy and install, unless you have an in-date British standards recognised calibration certificate for your guts then how they feel won't satisfy that.Gut feel says that's more likely to be a problem with new devices than used ones. If you're making fake MCBs why go to the hassle of making fake used ones, given the very much smaller market?
I wish I'd never mentioned it - I was never suggesting that people should trawl eBay for second hand CUs, or install s/h components without the customer being aware, only pointing out that sometimes a used device is worth considering and that there really is, logically, not necessarily as much difference between using an MCB that used to belong to Fred and using an MCB that used to belong to Fred because you've just bought Fred's house as there might appear.
But I'm obviously failing to explain myself, so I'll stop trying.
I've looked at this company's prices before, and always found you can do better (e.g. Gil-Lec, or Expert Electrical), but you do need to compare like with like.
