fused spur and faults | on ElectriciansForums
Discuss fused spur and faults in the Australia area at ElectriciansForums.net
hi everyone
if i had a fault on an outside socket and the fused spur was switched off inside what controls outside socket would it still trip the rcd
hope that makes sense
Don't see how you're going to trip an RCD with no current flowing:)
It's a bit like saying "will my kettle trip the RCD if it's switched off?" - of course it won't.
RCDs monitor current out (line conductor) against current in (neutral conductor) - if there's no circuit, there's no current to monitor........nothing to do with the earth:D
except under fault conditions
which is what im guessing he has
ie the spur is off the ring which in turn has a load on it
He is saying he has a fused spur going to an outside socket and this socket has a fault on it.
If the spur is switched off inside - can the outside socket still trip the RCD - of course it can't! :)
Reply to fused spur and faults in the Australia area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
