Fused spurs | on ElectriciansForums
Discuss Fused spurs in the Electrical Course Trainees Only area at ElectriciansForums.net
Wilson12
Trainee
London
I have come across a situation and need a bit of help.
With a switched spur the load is connected in load and supply in supply
I have done that for a towel rail but also tgere is a second spur being feed from this spur do I connect the cable for this in the supply or load if it's a switched fused spur being feed thanks
if you fed the second FCU from the load side of the first one, then that first FCU fuse will be taking both loads, and also, sitching off FCU 1 to isolate it's load would drop the supply to FCU2.bad idea.
Reply to Fused spurs in the Electrical Course Trainees Only area at ElectriciansForums.net
