Fuses blow when I put phase and ground wires in contact even when light switch is turned off | Page 2 | on ElectriciansForums
Discuss Fuses blow when I put phase and ground wires in contact even when light switch is turned off in the UK Electrical Forum area at ElectriciansForums.net
daz01FR
France
Hello to all, I stumbled upon a strange problem this morning. I wanted to change the light bulb socket in my bathroom, when I noticed that when the ground and phase wires come in contact,the fuse-box trips even though the light switch is turned off. So I took a pen voltage tester and tested all three wires. When the switch is off, the pen doesn't light up on any of the wires. When the switch is turned on, the pen lights up only on the red phase wire. Everything looks normal at this point so what could be causing this?
[ElectriciansForums.net] Fuses blow when I put phase and ground wires in contact even when light switch is turned off
French regulations require dual pole MCB's and RCD's, lighting can be either conventional or through a latching relay, switched live is always Orange to bulb, if multiple switched then Violet is used between switch's.
so much for the much hated harmonization of colours. were we the only ones to be stupid enough to change?
The OP is in France, so should follow the french regs or norms as they are called, all conductors must be of the same size so UK T&E does not conform, in twin brown or any other colour. :yum:
No we are the only one's who insist in using T&E and have to sleeve the switched wire.
One problem is we simply sleeve it to say the neutral colour should be considered as phase/live. We don't have any standardised colour or marker to say it is switched live, instead of permanent live, etc.
See past threads about (ab)using 3-phase + E cable and which phase colour should be switched-live and which colour should be sleeved for neutral.
Now if only we had a standards body for electrical work...
Exactly the point, if the UK used single core cable instead of T&E then switched live could be in Orange and easily identified, why the UK persevere with T&E I don't know, I think it may be used in Gibraltar and some other obscure ex Empire countries, but not the norm world wide.
I think a reason for T&E is the fact it has a sheath and can be run most places that don't present a major damage hazard. Otherwise we should be running conduit of some sort to all switches and accessories (could be flex plastic, etc) to allow such a solution.
Reply to Fuses blow when I put phase and ground wires in contact even when light switch is turned off in the UK Electrical Forum area at ElectriciansForums.net
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
