Fuses blow when I put phase and ground wires in contact even when light switch is turned off | Page 3 | on ElectriciansForums
Discuss Fuses blow when I put phase and ground wires in contact even when light switch is turned off in the UK Electrical Forum area at ElectriciansForums.net
daz01FR
France
Hello to all, I stumbled upon a strange problem this morning. I wanted to change the light bulb socket in my bathroom, when I noticed that when the ground and phase wires come in contact,the fuse-box trips even though the light switch is turned off. So I took a pen voltage tester and tested all three wires. When the switch is off, the pen doesn't light up on any of the wires. When the switch is turned on, the pen lights up only on the red phase wire. Everything looks normal at this point so what could be causing this?
[ElectriciansForums.net] Fuses blow when I put phase and ground wires in contact even when light switch is turned off
Reply to Fuses blow when I put phase and ground wires in contact even when light switch is turned off in the UK Electrical Forum area at ElectriciansForums.net
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
