Garage CU and RCD in series | on ElectriciansForums
Discuss Garage CU and RCD in series in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Somerset
Evening all - got a question that i think i no tje answer but need some assurance!!
Putting a sub main (garage CU) with standard sockets and lights.
Feed to garage CU from suitable MCB in main board that IS RCD protected.
Now........testing ... Most garage CU come with RCD, my understanding is RCD in series a pain so looking for the correct way to test - or is it easier to get a sub main with a 100A main switch no RCD? Thanks
Thanks both - problem is the main DB is split load 2xRCD board so all MCBs are RCD protected gggrrrrrr!
i have a mk sentry metal db dual split rcd and just slid the rcds and mcbs up the din rail to make room for an mcb between the main switch and the first rcd. put a short buzz bar to connect it. [ElectriciansForums.net] Garage CU and RCD in series
Yes Change to Main Switch
How would you record the install? MWC for the main DB to garage DB ( assuming using MCB that is there already and has 6mm cable just re-routing) and EIC for garage DB
House CU to garage is “new circuit” and garage DB is a “new CU”, so both require an EIC to be issued and LBC notified.
Reply to Garage CU and RCD in series in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Ok I’ll try this when I’m down
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
To be fair to the installer, he pointed out the deficiencies of what is a 1970s installation. If it were a new build, I doubt the supply would be...
