Garage CU and RCD in series | Page 2 | on ElectriciansForums
Discuss Garage CU and RCD in series in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
How would you record the install? MWC for the main DB to garage DB ( assuming using MCB that is there already and has 6mm cable just re-routing) and EIC for garage DB
House CU to garage is “new circuit” and garage DB is a “new CU”, so both require an EIC to be issued and LBC notified.
Reply to Garage CU and RCD in series in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You cant just "avoid" the use of RCD's for nuisance tripping... it will depend on how the cable is routed. (ie buried less than 50mm) What has...
Thank you so much for that! When I went to do the Ze at the DB, I tripped the RCD in the CU in the house, I understand that's a hard question...
