garage cut out | on ElectriciansForums
Discuss garage cut out in the UK Electrical Forum area at ElectriciansForums.net
growler
Basingstoke
im running a 16mm armoured from existing house to new triple garage. the run of armoured is about 5 metres buried underground. do I need to provide an 80amp cut out for the swa as its going to come off Henley blocks ? sorry if this is a stupid question just lack a bit of confidence sometimes.
you need to fit a D/P switch fuse or D/P switch and MCB. 1. for isolation, and 2. for fault protection. 80A is about right for 16mm SWA. but you could reduce this depending on the load in the garage and whether or not you can obtain a satisfactory value of Zs.
Reply to garage cut out in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
