Garage power | Page 2 | on ElectriciansForums
Discuss Garage power in the UK Electrical Forum area at ElectriciansForums.net
London
If I connect 4mm2 armoured from a 32A mcb to a garage 30metres away do I need to sub-fuse box in the garage or can I just use it as a radial circuit?
The garage will have two sockets and fused down lighting.
Why 'must' this be a prime aim in a garage installation of two sockets and some lights?
I absolutely agree. Nothing needed In the outbuilding more than the sockets and an SFCU for the lights.
60898's won't fully discriminate whatever you fit.
Absolutely. Some people really dont understand this.
An issue with 60m of 2.5mm is voltage drop. In a district where voltage fluctuates, this may be an issue. In my place it is always 249-250 volt, so I am lucky, other may not be. So a 4mm cable may be the way to go, even though it appears oversized for the current it handles.
This is when the OSG is your friend, a quick look at Table 7.1(i) has some quick answers to most initial guess of current & length combinations.
However, the OP said the client wants 32A option for the future so that really pushes for 4mm cable now. Also the difference between 2.5mm and 4mm 2-core SWA is around the 50p/m mark so for 30m or so run around £15 and compared to the labour, etc, involved it is hardly worth arguing over!
60m
i though the distance was 30m ?
But we still use a nominal voltage of 230 at the design stage. Can you guarantee in ten years time that the voltages will be the same?
Not at all. But as a transformer is not far from me it is a good bet it will remain that way in my case. But generally you are right.
I recall one Dutch guy who said the British oversize cables. He said, with widespread adoption of LED lights you are still installing 1.5mm lighting cable when 1.00mm is more than adequate. Lightly used rings are oversized with a total of 5mm. But the oversizing may compensate, even if ever so slightly, over voltage drop.
[automerge]1591100612[/automerge]
60m
typo. approx 98 foot, a fair distance in a domestic house. Then wires off that.
You do get 1mm for light circuits and it is often used.
The problem is the IET regs have 1.5mm as smallest for power circuits (not sure exactly why, might be for mechanical reasons, or a throwback to the days of 15A rewirable fuses being the next size up from 5A) so for many a stock of 1.5mm is more generally useful stuff to have for odd fused spur, etc, as well as for lights.
Just poor design using 1.5mm when 1.0 would suffice in the vast majority of installations.
As an aside I use 1.0mm when installing new but a lot of installations in my area use 1.5mm so I use that when modifying or repairing.
Reply to Garage power in the UK Electrical Forum area at ElectriciansForums.net
My wife’s Evoque gets about 32 miles on a full charge and I get about 28 miles on my F-Pace. I don’t know how long a full charge takes but I...
Haha yes, it is. Must be a northern expression. Have a Google 😂
