Garage Sub Main BS1361 | Page 2 | on ElectriciansForums
Discuss Garage Sub Main BS1361 in the UK Electrical Forum area at ElectriciansForums.net
I am planning to run 6mm SWA from a main DB which is protected by a 40A fused switch. The SWA runs to a garage and is connected to a BS1361 40A, it then goes into an RCBO protected sub main board. Is the BS161 necessary at the sub main when there is 40A protection at the source?
Any advice would be greatly appreciated.
Hmmm, ...i have just read your OP again and i'm now confused or i'm missing something!! So which is it, ...are you installing this 6mm cable or is it existing?? Make you're mind up!!
A DIYr (previous owner) made it all a bit complicated not least, not connecting any external earths to the main ET of each board! All sorted with 3 new metal sub mains all containing RCBOs. I am just about to be assessed by NICEIC and wondered about BS1361's. The sub main supply goes from house and splits underground - one sub going to garage and the other to workshop.
Reply to Garage Sub Main BS1361 in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
