skmanuk
Hi Guys
I have a slightly unusual one here and would appreciate any advice/comments,
I have a detached house and detached garage, room over garage, both with their own supplies and meters. I belive the original purchaser at new build was going to run a business from over the garage and wanted a seperate supply. This of course means 2 lots of standing charge and high price initial units.
Client wants to link the garage to the house supply.
Both meter boxes currently have a 100A Isolator after the Meter and then tails to the CU's.
The plan is to run a 25mm 3 Core SWA from the house meter box to the garage meter box. In the house meter box I was going to split the supply after the 100A Iso using Henly blocks, and tie in the SWA earth.
At the garage end fit a new 100A Isolator, remove the CU Tails from the existing !00A Isolator and route the incoming SWA thro the new Isolator to the existing CU. Again tieing in the SWA earth to the existing earth.
A couple of further questions, should the SWA cable cores in the boxes be sleeved to blue and yellow/green?
How would you terminate the SWA into the bottom of the Meter box, simple remove the wire armour and innr protection and route up through the bottom enrty opening?
Thanks in advance.
Thanks in advance.
