Garage to be protected by an RCD | Page 4 | on ElectriciansForums
Discuss Garage to be protected by an RCD in the UK Electrical Forum area at ElectriciansForums.net
A
ash88
Hi,
I am an industrial electrician and have been asked by a friend to do some work on their house. I would like some advice on RCD's.
I have been asked to install a light and a socket in a garden shed. I am planning to supply the shed via the garage which already has a supply from a 32a breaker (which i am going to replace with a 20a breaker) seen as though it is run in 2.5mm SWA.
The garage circuit is currently not protected via any kind of RCD / RCBO. However, somebody has previously installed an RCD next to the house consumer unit, and has routed the house sockets circuit through it.
Will the RCD previously installed for the house sockets interfere with an RCD if I put one in a 4 way consumer unit in the garage?
Cheers.
Reply to Garage to be protected by an RCD in the UK Electrical Forum area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
