Garden distribution board | Page 3 | on ElectriciansForums
Guest viewing is limited
Discuss Garden distribution board in the UK Electrical Forum area at ElectriciansForums.net
N
ncpitts
Hi all,
I would like to pick your collective brains by asking if any of you has installed a DB/consumer unit in a garden or outside which is flat and flush to the ground . This one is by a lake and needs to be flat. It will be sat in grass/lawn
Ideas or solutions please
Ta lots
Nigel
It's a rediculous idea in the first place, you know that, but you didn't offer up a (equally daft) different solution.
Offer up some ideas yourself for discussion.
So because I don't post an idea you won't, 6000 posts for that. Come on, think , yes it maybe a ridiculous idea but they said that about the Wright brothers. Is this so difficult , it's crazy admittedly but is it impossible ??
9478 posts and carrier bags are the sum total of wisdom.
The customer is a very intelligent man so if an IP68 box is placed in another and then another (which what he suggested) do you have any scientific reason why not as I'm struggling,I know it's not right but am having difficulty arguing with his logic)
Yep, he sounds like a very intelligent man indeed!! .....NOT!!
So how would you seal the cable entries into the outer and inner boxes and exactly how long do you expect them to be water tight?? Then how are you going to overcome condensation, which is almost a certainty with the box(es) being sunk into the ground??
You're the man on site, I can't see anything from here.
Give us some ideas, it's very easy to post some pictures up!
Don't worry about the urine taking! :)
Excellent! condensation, hasn't crossed my mind, now that's what I was after !
Cheers buddy :)
You seem very hung up on post counts mate.
Your options are fairly limited,
1 Use the CU in the property or install a new/secondary one and run SWAs to the various places in the garden
2 Build a substantil structure hidden somewhere in the garden to hide a CU, then run SWas to the various places in the garden
3 Run SWA to feed a new CU in a weatherproof box which will be visible because of it's proximity to the places where power is to be used
See post #28 re the condensation thing.
It is not impossible to physically do, but what you need to consider is whether it should be done or not.
There are a few regulations that you can use to knock this idea into touch!
Reply to Garden distribution board in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
