Garden distribution board | Page 4 | on ElectriciansForums
Guest viewing is limited
Discuss Garden distribution board in the UK Electrical Forum area at ElectriciansForums.net
N
ncpitts
Hi all,
I would like to pick your collective brains by asking if any of you has installed a DB/consumer unit in a garden or outside which is flat and flush to the ground . This one is by a lake and needs to be flat. It will be sat in grass/lawn
Ideas or solutions please
Ta lots
Nigel
There’s away around everything if you just look.
Replace the links with fuses and the jobs good to go.
[ElectriciansForums.net] Garden distribution board
Tell him it's a stupid idea, and this "intelligent man" should know better, oh sorry intelligence and common sense aren't the same thing are they. His suggestion is one of the most idiotic things I have heard CU flush with the ground.
So apart from insulting my customer, have you anything constructive or scientific to either help to accomplish this task or an alternative to what he wants ?
No not really, you have to admit though it is a daft idea, perhaps what I was really trying to say was explkain to him/her the futility of trying to do what he is asking for, the inherent dangers etc.
Thanks to all l who have contributed an idea to either do this or have given a good reason why not.
To be clear there are ducts dug into the ground and the board has next to nothing in load terms. All the calcs have been done. I think it's not a good idea but thought I would get some other opinions.
For those who didn't posting insults or crap about plastic bags etc. I would like to say that if you have nothing constructive to say then please say nothing.
Thanks again
Thanks again
Muppet,
Why didn't you include the bulk of this post in the original - if you had, you may well have got more sensible posts earlier on.
I'll leave now to let you dig a hole for the CU and another for yourself.....
I would say this needs to be in the DIY section, but after reading the OP again and the reply from the Muppet I would recommend it is removed from public viewing just incase someone else thinks it is a good idea, Gasp!!
Sorry boys, I think you're all being a little too set in your ways with this one. It's all in a days work for an event sparks, eh Dave?!
If loading is light, so heat unlikely to be much of an issue, then there are bound to be lots of products designed for marine environments and so on that will do just this job - it's just a matter of finding them. And yes, you probably could fit a lidded IP66 DIN rail box (to house the CPD) inside another much larger one which had the entry glands internally resin-ed off, etc etc.
Good grief, there's thousands upon thousands of underground joints and junctions, BT wiring centres etc etc in the UK - do you think they all rely on jokes about carrier bags??!!
The person who says it can't be done is normally followed by the one who just did it - and they are the person that gets remembered.
Rockingit, Thanks buddy , outstanding at least it gives me a way forward
Took 56 posts but found the nugget eventually
Yep, he sounds like a very intelligent man indeed!! .....NOT!!
So how would you seal the cable entries into the outer and inner boxes and exactly how long do you expect them to be water tight?? Then how are you going to overcome condensation, which is almost a certainty with the box(es) being sunk into the ground??
Watertight we can do , good grief we put lights in swimming pools, selv admittedly but still watertight.
Condensation is another problem entirely
Muppet,
Muppet - really are we down to that ?
Installation method and load are not the problem.
How to do this is, this is not why the posts were not sensible, its an idea that is out of the box ,that is why we got that type of reply
back to an earlier one if you don't have anything constructive to contribute then contribute nothing.
however thanks for at least having a look
Thanks again
Reply to Garden distribution board in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
