Garden lights tripping | on ElectriciansForums
Discuss Garden lights tripping in the UK Electrical Forum area at ElectriciansForums.net
R
Rauer
Got called out to someone's garden spike lights tripping out , gu10's metal bodies but there only 2 core flexed! Now the cable is an armoured that is buried and all joints have been resin'd up and no work has gone on in the garden ( apparently) the ir result is 0.14 e-n and l-e ( havent taken the lamps out as of yet!) I was thinking ( I know that thinking is dangerous!!) If one of the neutrals or live has come into contact with the body of the fitting, and the fitting is inserted into the ground ( it's a spike light by the way) could that be the cause? As outside there is also a pond and a hot tub!
Only trips under load so I am guessing l-e and I know it's naughty but it trips with the e disconnected hence me thinking traveling back up the water feature and hot tub e!
Reply to Garden lights tripping in the UK Electrical Forum area at ElectriciansForums.net
If it's underground I've always favoured SWA with good old fashioned resin joints. I would make a 3 way resin joint below ground, no enclosure...
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
