Guest viewing limit reached
What meter are you using magill? Most modern low ohm meters should be capable of a resolution of 0.01
Edit: Thinking about it (I'm trying to work on my laptop as well as desktop, multitasking is not my strongest point) - Most meters have an intrinsic accuracy of about +/-0.05 ohms. So go with spinlondon's advice. We're trying to split the atom here. If shows zero you may have found the mythical superconductor.
It's good enough :-) how do you get smilies on here?
Actually, thinking about it again (sorry to be boring) I have used my trusty Megger BMM503 to calculate the lenght of cable left on a reel, and it's pretty bloody accurate within a couple of metres.
Right, i've now changed one of the leads and am now getting a reading of 0.5 ohms. (Using a Fluke multimeter).!!!
What 'lead' have you changed? It's now reading 10 times higher than maximum allowable?
Beg or borrow a recently calibrated meter from a mate or test yours on a known resistance!
Gas supply earth connection
magill,
terminator,
