Ge rcbo | Page 2 | on ElectriciansForums
Discuss Ge rcbo in the UK Electrical Forum area at ElectriciansForums.net
bartkusal
London
Hi all,
Just a quick one, can anyone advice where I can get General Electric 6A 30mA RCBO type B, looked on int. couldn’t find, just type C. Seems that it very unpopular. Alternatively, what other RCBO will fit that board, the board was installed in 2000, it is a split board, only half protected by RCD, and I am working on the lighting circuit which is not.
Thanks in advance for your help.
Regards: Al
I must say it makes a welcome change to see someone being concerned with conventional Zs values being maintained...lol!! In this case however, you should be well under max Zs values with a 6A type C RCBO, which will also extend (artificially) max Zs to 1667 ohms... lol!!
Reply to Ge rcbo in the UK Electrical Forum area at ElectriciansForums.net
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
7K
suffolkspark
