Generation meter position for multiple inverter installs.
gr7
I have 2x inverter domestic installation and need some advice on the meter position.
In order to meter generation from both inverters, and both inverters needing a separate MCB, I need to place the meter before a 2 way CU. Would the correct approach to be take tails directly from a henley block to the generation meter, then from the meter to a dedicated 2 way dedicated CU.
What do others do on these jobs?
We would put an isolator between the henley block and the gen meter, then the dedicated cu, then two isolators (one each) etc..
Same method's good for microinverters, where there is more than one radial circuit feeding several inverters eg on differing roofs
gr7,
edexlab,
