Generator Build | Page 2 | on ElectriciansForums
Discuss Generator Build in the Electrical Course Trainees Only area at ElectriciansForums.net
GMES......that work looks really interesting...i used to do machine builds and refurbs when i was an apprentice (at the time i couldnt wait to get out and get ****ed) now looking back it was really interseting stuff.
is this your main job? i.e building generators or are you a maintenance engineer?
cheers
cheers
No Ste I am an industrial electrician, mainly installation work 3 phase power boards etc nearly all 3 phase really ,today as an example we are replacing a load of 3phase busbar with the tap offs to 10 cnc machines, I also did a lot with the big American tyre shredders Granutech.
Also got 2 large factories to test over the next couple of weeks. Always something different which is how I like it Mate.
Good stuff mate, thats the type of work ill be aiming for..........how many years you been doing this?
Here you go Ste, a couple of pics from today of the Busbar and the supply
[ElectriciansForums.net] Generator Build[ElectriciansForums.net] Generator Build[ElectriciansForums.net] Generator Build[ElectriciansForums.net] Generator Build
Bloody sideways again sorry mate.
nice....do you work on the control side also?
Yes mate, do quite a bit of machinery, Tyre shredders, packaging machines, industrial ovens and furnaces + much more which means I provide a Breakdown service to all my regular customers, there are a few that run 24/7 but I am usually safe after about 10pm.
Regarding years I have been at it for about 15 years now, so not as long as some of the old boys on here.
Sorry for the late reply my personal computer is broken......
Looks like you have a great job mate, lots of variety so always busy.....if your'e ever working up Newcastle way and need an unpaid hand, id jump at the chance....
cheers
cheers
Cheers Ste and good to know about the helping hand, will bear it in mind cheers pal.
I ripped out a ton of that very same busbar a month or so back, skipped the lot, tap offs the lot, if I'd have known you could
Have had em
Not that I ever get to work on any of it but we have a lot of old square d busbar and tap offs in our place
Also square D switchgear but that's about to be replaced by the new kit in front of it
Not sure if they will splash out on some new tow rope as well
1st time I've posted pics with tapatalk so not sure they will work[emoji3]
Have had em
Typical that mate, it just cost the customer 2500.00 in replacement Canalis busbar but luckily the old tap offs were compatible.
Reply to Generator Build in the Electrical Course Trainees Only area at ElectriciansForums.net
Think all has been covered already, but echo-ing the above if I was getting my DB swapped and had a 3 phase head, I would put a little TPN board...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
