genuine question | Page 2 | on ElectriciansForums
Discuss genuine question in the UK Electrical Forum area at ElectriciansForums.net
M
m1ck_b87
Hi all I know a lot of people on this forum won't know this so I'm going to bring it up, potential difference.
Potential difference is voltage, so if I measure between live and a metal object will I get 230v. It is a difference in potential at the end of the day.
Minimal potential difference between feet. Electricity likes the path of least resistance. Offer the bird a nearby ground potential and you get a fried snack as the current wants to get to earth and the bird becomes the conductor
Why doesn't the electrical current pass through 1 birds leg and out the other and fry the bird
in actual fact, some current will flow through the bird's legs, as the bird is a parallel resistance to the wire it's standing on. however, the resistance of the bird's body is far greater than that of the cable between it's feet and so the current flow through the bird is negligible.
google resistors in parallel.
Having thought about your question a little more I think the easiest explanation regarding the bird on the wire is that the electrickery is flowing up each leg at the same time and meeting in the middle, both currents being equal, one is not stronger than the other so they just kind of stand there butting heads and getting no advantage, were you to fly up and touch the bird with one hand only you'd die because the electrickery is only entering your body through one point and doesn't meet the opposing current coming the other way. Grab it with both hands and you'd be ok though.
I am of course taking the p.
And to be fair to us we're always up for a bit of sport, it's just your poor luck that you were it tonight. Don't worry though it'll be someone else tomorrow and pretty soon you'll be joining in with us. We don't mean to be nasty, it's all Tel's fault he made us do it :)
Reply to genuine question in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much I have spent hours and hours looking for this answer, appreciate your time and comprehensive reply. I will look further into the...
CIS registration is pretty simple. Give the CIS helpline a call and request to be activated as a cis subcontractor. Not contractor though, there...
