genuine question | Page 3 | on ElectriciansForums
Discuss genuine question in the UK Electrical Forum area at ElectriciansForums.net
M
m1ck_b87
Hi all I know a lot of people on this forum won't know this so I'm going to bring it up, potential difference.
Potential difference is voltage, so if I measure between live and a metal object will I get 230v. It is a difference in potential at the end of the day.
And to be fair to us we're always up for a bit of sport, it's just your poor luck that you were it tonight. Don't worry though it'll be someone else tomorrow and pretty soon you'll be joining in with us. We don't mean to be nasty, it's all Tel's fault he made us do it :)
We have to do as Tel says!
when you test from L to E, a current flows through the meter. if your meter is set to volts, then it will read the voltage , or potential difference between L and E. obviously, the meter is high resistance, so the current through it is small ( mA ).
The voltage at each of the birds feet is the same sitting on hv cables. Voltage is the energy that 'pushes' current or as some one once said to me, the pressure. If there is no potential difference (voltage) between the birds legs then there is no way that current will flow. There is no pressure to push it.
Incidentally if you find that your bird has voltage between her legs, be very careful. There is a thread on here showing what could happen and it's very funny.
It shows she hasn't thrown her toy out of the bed.
Reply to genuine question in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much I have spent hours and hours looking for this answer, appreciate your time and comprehensive reply. I will look further into the...
CIS registration is pretty simple. Give the CIS helpline a call and request to be activated as a cis subcontractor. Not contractor though, there...
