GFI in boat dock not working | Page 3 | on ElectriciansForums
Discuss GFI in boat dock not working in the USA Electrical Forum area at ElectriciansForums.net
Tahlequah, Ok
Had an electrician install electrical in our boat dock, but none of the three square d gfi breakers are now working. I unplugged the overhead door motors. Still the breakers will not reset. Tested hot at all three breakers, and everything in the box looks clean and new, so I doubt lightning strike. Ideas? Could the incoming power line which is direct burial cable which comes in just above the water level, be the cause of tripping? On my way back from the lake, I realized that I had not reset the power. These breakers are post 2003 models, so do they have to be reset by turning off power to them?
I am just a diyer, so any suggesting will be appreciated. Called my electrician but he is, as usual, too swamped to respond...
UPDATE;
Thank you all for the helpful advice. I tried resetting all the way back at the meter, with no effect on resetting the GFCI breakers. Since I was now at the end of my knowledge, I hired an electrician. He checked it out and found that otters (or something) had chewed through the electrical cable feeding the dock, so we were getting no power to the dock. Repaired the broken cable, and all is well.
Congratulations my friend and glad your problem is resolved
Reply to GFI in boat dock not working in the USA Electrical Forum area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
I’m trying to replace a gfci outlet which does not work in a bathroom at a relatives house which was just purchased. Circuit checker shows no...
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
