Glands without shrouds? | Page 2 | on ElectriciansForums
Discuss Glands without shrouds? in the UK Electrical Forum area at ElectriciansForums.net
davesparks
Personally I think A CW SWA gland looks a lot better in a finished job without the shroud than they do with it, especially when there are 8 RGM glands in a row next to it, but does any one know of any reason why not fitting the shroud would be a problem?
The gland is indoors in a dry and heated space so no worries about environmental considerations, and even if there were I think the shroud only ever serves to trap moisture around the gland which achieves a high IP rating on its own.
Obviously the shroud is useful for some people if they are not very good at actually fitting the gland properly, but I like to think I'm reasonably capable of fitting an SWA gland properly
They were being pushed over here for a while, I've never used them but I'm rather partial to adhesive-lined heatshrink, Thermoform trifurcating boots / trousers and the like, so they look quite tempting. Other than for temp rating which might limit the cable performance.
I like the adhesive shrink, but only when it's required/suitable. I can't see that it has any advantage over a pot and seal termination on MI other than being maybe a little bit quicker and probably cheaper. But anyone installing MICC these days isn't likely to be on a penny pinching mission.
Though I have done some temporary creative bodges with self amalgamating tape to get things going until the right stuff can be delivered. So I guess a heatshrink option could be useful for the occasional repair, but then I think most of us could manage to cute our own without having to buy a special branded pack of heatshrink!
Do any of you remember those crimp on pots? It was a new system, then, that came out about 35 years ago from, I think, BICC.
It didn't really take off and didn't last very long. Can't remember too much about them but I think they pushed on and then a tool compressed the pot to the sheath.
With the split collet in the back, and the gland with the inner knurled nut? Yes, and I've got the tool, but they were before my time really. I still have some cables in service on my patch with them on though.
drill and tap an M4 besa box screw into the side of mine tomorrow
Ah, you working round the weekend too? I'm still in the machine shop, about to grind to a halt for want of 2.5 bootlace ferrules. Wish I could get out a bit and bash some MI.
thats always anoying running out :( some ----- kicked my numbers box over in the week.
18 compartment box and it was full..... took fooking hours to sort.
2.5 are grey right?
ive ordered a load of pots and im going to order a load of numbers to keep some in stock on the van
They're the ones...you forced the gland back with the tool and it compressed the split onto the sheath. I couldn't stand the things, to tell you the truth.
I'll swap you all my 2.5 bootlaces for some RGM2L.5 cos I didn't order enough and I'm supposed to be finishing tomorrow.
I'm going to have to raid the box of miscellaneous MI bits in the shed in the morning.
I've already gone through the small stock of space rangers I've got but none of them go down small enough for 2L1.5
I think I might have to get a little creative tomorrow! If it was pots I was short of I old just solder the next size up onto the cable instead of threading on, but I'm not sure I'd get away with something like that on the compression ring.
Wedge pots I think they were called, I've ended up with one of the tools somewhere I think (like a pair of adapted mole grips)
RGM2L.5?? I'd like those. Cable would be 4mm O/D and good for 10A. I wish they still made 250V 0.0015, smallest 2C+E wiring cable of all time, 0.187" O/D from memory.
Haha, at least you knew which was which by the numbers on them! I've recently done my S/S M3 screw kit which took a leap off the bench, Got bored about halfway through the washers and swiped the rest into the bin. My main ferrule kit is still on a job in Regent St. like my Big Box of Wagos and other really handy things, but I'm in the works at Hatfield, so been using up what I had in the trays here.
2.5 are grey right
En France bien sûr, aber in Deutschland sind sie blau.
Right, no more tri-rated today, Derek and I are packing in, quick beer and half an hour doing a schematic of what I'm going to make tomorrow. Thanks for the chat, not enough serious wiring tech talk around this place at times.
OK put a few strands of flex through and then jam the cable in. Or smoke paper or whatever. It's only plumbing so do whatever a plumber would do. Which brings us back to push-fit glands. Good night.
i only use the colour coded ones, i wouldn't have attempted it if they were the white ones.
im not joking but i had an 18 compartment metal box that was half full emptied on the floor 6 pots completely full of mixed numbers before i started.
im going to slip a bill onto the guys desk for a full set of replacement numbers and ferrules. .75,1mm,1.5,2.5, rubbers and doubles XD there more expensive than you think
If I'd known you were in London we could have met up last week, I was in the criterion on Friday,
I'm possibly back there for a day or two next week too
Reply to Glands without shrouds? in the UK Electrical Forum area at ElectriciansForums.net
