that's the problem in a nutshell. nobody knows what firmware update is required, even Power-One, who appear to be stuck in the coding cycle I gave in that post.
Here's the installer version of that cycle.
It's all a bit embarrassing really.
We now seem to be stuck in an eternal feedback loop between lines 90>110, and I suspect Power-One engineers are currently wibbling in the corner hoping everyone just forget's about the issue and stops using the remote display units / learns to live with the glitch.10 Install system
20 find glitch in the data between the inverter and display unit
30 ring Power-One to report the problem
40 Install firmware update
50 find this only solves one part of the problem
60 ring power-one to be told ah yes this is a known fault, we're working on a fix for it and should have it sorted in the next few weeks, we'll put you on a list and get back to you
70 customer rings up to chase progress
80 installer rings power-one to be told we they'd set up a new way of reporting the fault so our customer isn't actually on that list, could we give them the details so they can be added to the new list and they're working on a fix and expect to be sending an engineer round in a few weeks time
90 2 months later customer rings to say they'd had no contact from power-one
100 installer rings power one to be told they thought they'd solved it but actually it didn't work, so they're working on another solution which should be ready in a few weeks
110 Go to 90
