going to try a 'pro' alarm install | Page 3 | on ElectriciansForums
Discuss going to try a 'pro' alarm install in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
purchased the usb lead and managed to pair with wintex on my laptop
is there a good pdf guide with all the terms defined- so I know exactly what I am setting each zone to??
for example quite a few zone type options: entry1, entry2, guard, guard active etc etc
cheers
Texecom for me. 4K7 resistor in parallel across alarm and 2K2 resistor in series for tamper. Say you use yellow and blue as your zone wiring.... In the PIR take yellow to 1st alarm terminal with one leg of the 4K7 resistor twist the other leg of the 4K7 resistor with one leg of the 2K2 resistor and terminate it in the other alarm terminal, other leg of the 2K2 resistor goes into one of the tamper terminals and blue connects to the other tamper terminal. Buy the USB com lead, register as an installer and download Wintex. It's an absolute doddle to set the panel up with Wintex and takes only a few minutes. For the bell box go for the texecom odyssey X3. If the wall hasn't been plastered yet where the RKP is then buy the recessed back box and install a flush keypad as looks better. I normally put a Ricochet expander in as standard and use the ricochet micro door contacts as looks 10 x better than the usuall bulky door contacts you normally see. They are tiny and you don't have to staple a cable to it.
Texecom DBE-0002 Premier Elite FMK Flush Mounted Back Box for Texecom Premier Elite Keypads - Texecom Premier Elite Alarms - Security Systems - Security - https://www.powersaver.co.uk/security/security-systems/texecom-premier-premier-elite-panels-accessories/texecom-dbe-0002-premier-elite-fmk-flush-mounted-back-box-for-texecom-premier-elite-keypads.html
Odyssey X External Sounders - Texecom - http://www.texe.com/uk/products/series/external-sounders/odyssey-x-series/
Texecom USB-COM Interface Connector JAC-0001 - https://www.alertelectrical.com/texecom-usb-com-interface-connector-jac-0001.html?prod_id=1036&gclid=EAIaIQobChMIv4uosJHq2AIV7ZTtCh2Jhgi6EAkYASABEgIF1PD_BwE
Texecom Ricochet 8XP-W Ricochet Wireless Expander GCD-0001 - https://www.alertelectrical.com/premier-elite-8xp-w-ricochet-wireless-expander.html
Register - Texecom - http://www.texe.com/int2/register.php?act=forgotten
Software & Peripherals - Texecom - http://www.texe.com/uk/products/range/software-peripherals/
cheers
Reply to going to try a 'pro' alarm install in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Shhh, don't tell the Chinese they want a bit of the action.
