Good Morning Thread - Come say good morning, tell us what you've got on today. :)
Note to self.
When drilling a fixing hole into pvc conduit box.... Do it on the floor, on a piece of wood, holding it steady with your size tens.
Do not just try and hold it in your hand and brace against your leg while you're kneeling down.
Yes, ladies and gents. I drilled into my own leg.
We wear boots for clamping anything that needs drilling.
Have to admit to regularly holding PVC boxes in my hand when drilling. All fun and games until one tooth catches.
Note to self.
I have always drilled a fixing hole in any type of conduit box, however was watching a YT electrician and he states its not necessary as its supported by the conduit saddles etc.
I don't know anybody that relies on that method.
There are moulded dips in a conduit box which invites being drilled through… so I think it needs to be done.
Next you’ll be saying everything needs to be glued together. 😂
The only conduit boxes I have fixed in place with a screw inside the actual box are some terminal, angle or through boxes that are fitted with a cable gland for a flexible going to a fitting or appliance. All others have been supported by adjacent saddle clips.
Two good reasons are that a metal screw compromises the !P rating of the box, especially against water ingress, and there are often live joints inside a PVC box, creating the risk of a short to the metal screw head.
So you would happily have a bank of fluorescent fittings on two foot centres (could be on jack chains) only being supported by the saddles. NOT ME
My OP was specifically PVC conduit boxes, and drilling them. I suppose it might be different whether I fix the box itself if it were metal, needed a high IP level and had nothing hanging from it.
Most batten light fittings come pre drilled (or pre marked for drilling) to fit on 2 boxes.
That’s it! The world has now officially gone down the pan!
Brexit, covid, Ukraine….that’s nothing.
It has been announced this morning that….
Bounty’s have been omitted from this years boxes of Celebrations.
Shock and horror!
And it’s not down to coconut shortages or anything… it’s only because they say 39% of people don’t like them.
I’ll have theirs, then!
Are they phasing them out quietly? Oh nooo!
“Limited edition” emblazoned across the box lids….
They’re using it as a marketing ploy,
Well, jokes on them. I demand we all boycott celebrations!
Unless the start making boxes with ONLY bounty’s in them.
Dan,
littlespark,
