Discuss Good Morning Thread - Come say good morning, tell us what you've got on today. :) in the The Electrical Exchange area at ElectriciansForums.net
Ha! I was looking at exactly that same Ubiquity combination earlier and emailed a local distributor for further advice. However, does the Sky box still not want to act as DHCP server and be a bottleneck?
No, it will issue a single ip address to the dream machine.
Say 192.168.1.2
The dream machine will handle dhcp requests and for instance hand out the whole range from 192.168.0.1 to 192.168.0.255
The sun is out, the sky is mainly blue and hopefully it'll be a good day. Yesterday was a pain but today looks promising. 3 x 400kV bushing oil samples, run diagnostics on a DGA analyser and prepare things for tomorrows transformer testing.
Morning @pirate @Moley @James
Might try that router thing for sky I could get rid of the virginmedia if the house didn't thrash the sky.
But the bushing oil thing goes over this layman's head 🙄 😒 😑
But that's fine ha
I've got clouds from north to south above me now. Mind it's 3 hours after you'd said. @Lou said we are having a 16hr storm Sunday night Monday morning but we had a teaspoon of rain. So has this storm gone somewhere else then or what.
Gas boilers must be being turned on as plumbers has started it's surge in 'my boiler won't turn on' type people we get around this time of year. That's the official end of summer for me.
Say 192.168.1.2
Presumably though you have to turn off DHCP server within the sky box? And thus assign a static IP to the dream machine first?
How many simultaneous ranges can the DM provide under the same subnet? Using a class A I'd been looking for all three of 192.168, 10.x and 2.x's
ps - it won't ever issue a x.x.x.255 address as that's reserved, same as x.x.x.0
You can setup multiple network blocks, V lans, separate wifi networks running on the same access points. (If using there own access points)
DHCP can remain on for the sky router as it will give an address to the DM.
All network stuff is handled by the DM and only internet traffic is forwarded to the sky router, DHCP requests will not be forwarded through to the sky router.
Thanks for this. All the AP's on POE or are there 'mains and mesh' options?
they are all POE however, if you cant get a network cable to a location, a poe injector will suffice and the AP will work in mesh mode. infact, if you have a pc near to it, then you can use the uplink port on the poe injector as a network port for the pc.
[ElectriciansForums.net] Good Morning Thread - Come say good morning, tell us what you've got on today. :)
below, you can see that i have 2 wifi ssid. one a 5Ghz (fast) for most devices and a slower 2.4Ghz one as not all my smart home devices support 5Ghz
I have a single flat network but you can set up multiple networks and V lans if required
Just a quick comment to confirm that Ubiquity is excellent gear, I've used their network switches, AP points, point-to-point line of sight links and cctv cameras on a few jobs. As above, injectors are available and mesh mode works well.
the only thing i would say is that their cctv cameras are expensive compared to others and their recorders will not accept feeds from other cameras.
other than that, they are my go to supplier for networking equipment now.
Well, 24 hours late but this is what we did yesterday morning
Plus 3 sets of these
Just managed to finish before the rain. Back home today. Got to pick the mother in law up from hospital this morning so my back up pension plan isn't working 💀🤣
That's mint @Moley !
Proper stuff! What 'qty' of power would run through that then. Like should it carry and how long do they last?
Reply to Good Morning Thread - Come say good morning, tell us what you've got on today. :) in the The Electrical Exchange area at ElectriciansForums.net
This is an RSS feed of thread: Morning Everybody - Hope all is well? - What have we got on, how are we all doing? Content of the thread: Morning...
Which truly is the Number 1 Best Tile Adhesive Brand? Since 2007 Tilers Forums started an annual best tile adhesive Poll and sent it out to the...
