I only earth the front plate, but I have no problem with those who earth both. It was the good practice bit that I saw red with.There is a difference.
Would you earth a back box and rely on the screw to run the earth to a socket?
Discuss Good Practice. in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
I see, I agree with that.I only earth the front plate, but I have no problem with those who earth both. It was the good practice bit that I saw red with.
Just had a look through the old thread seems an age old argument.Found this from last year Westward, and some have used the term 'Best Practise';
Earthing a back box - http://www.electriciansforums.co.uk/threads/earthing-a-back-box.106636/
Now I'm one of those that use fly leads, I even sometimes add them to an existing install, if replacing the front plates for example. Not sure I would be so bold to use the term myself, cos it suggest it's from some form of guidelines or teaching.
Interesting point about Guidance Notes, as opposed to the gospel as is BS7671.
PS I did think of posting on that old thread, but that would be just stirring things
I don't have a problem either, but yeah sticking more than one cpc through a sleeve now that ain't good practice.I don't have a problem with either method just dont twist the cpc's all together and then cover in sleeving?
Why bother with sleeving, it was okay prior to 1966'ish. Must have been good practise then
third rate iron was used to make rivets for the titanic.Why bother with sleeving, it was okay prior to 1966'ish. Must have been good practise then
Oh the ironythird rate iron was used to make rivets for the titanic.
Not many cpc's around then.Why bother with sleeving, it was okay prior to 1966'ish. Must have been good practise then
Was on the 'ring mains' and radialsNot many cpc's around then.
Yes indeed.Was on the 'ring mains' and radials
Reply to Good Practice. in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
