got a call today | Page 3 | on ElectriciansForums
Discuss got a call today in the UK Electrical Forum area at ElectriciansForums.net
G
glasgospark
self employed spark had fitted rcd protected DB to replace 3036 board
after fitting everything plugged in to a socket and turned on would trip rcd , on both rings and when the heating switched on
declined the job to busy and KNACKERED/GRUMPY today but wondering what you guys think , it was a rcd main switch so no dual rcds to worry about getting neutral in the right bar
Did the 'self employed spark' not properly inspect + test and issue an EIC when doing the board change?
Nothing should be tripping if he had done the job properly.
Guaranteed the 'spark' can't sign his own work off - so the likleyhood of their being an EIC is probably nill.
clearly this bell end didn`t bother with `technical stuff` like that.....
never mind eh...
Reply to got a call today in the UK Electrical Forum area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
2 3
