Grade A Fire Detection Advice/Installer Required
In my 3 storey house I need to fit a grade A LD2 alarm system. Mains connected grade D currently exists in the correct locations but I guess because they are not fed by FP cable I will need to rewire to the new detectors I'll need to purchase, which I am capable of doing.
What I can't do is connect it all up to the control panel and the control panel to the consumer unit. I will also need a certificate. For this I would hire someone.
Questions:
Does the above sound like a reasonable way of lowering labour costs that an electrician can work with?
Does all FP cable need to be enclosed in trunking (even if inside a cupboard or in the loft)?
Is the interlink cable separate?
Any advice for how to get this sorted as low cost as possible? Happy to receive quotes (NW London).
Questions:
Do nothing without the express permission, and following all lawful orders, of the electrical contractor/fire alarm installer.
I would be employing someone from the outset to do all the installation work, the questions you are asking suggest you are not competent to be doing this.
ahhaah,
ahhaah,
