Discuss Greatest Electrical Game Changers in the UK Electrical Forum area at ElectriciansForums.net
it's in season for clockwise haggis. out for anti-clockwise. you need to check the legs. clockwise haggis have the right legs short and the left legs long.Haggis hunting? Out of season?!
Tel, I believe you may be right...however, the true Spawn Of The Devil is...
the inkjet printer!
Many of you will know EXACTLY what i mean!
agree. my right foot has served well as engine management for 60 years. why change what ain't broke.Biggest con-job after ECUs and Certifications
I've not used a non-network printer for ... a long time. Being a Mac user we've been used to being networked a long time before it caught on in the PC world, and we didn't have to fight the system to make them work (mostly).I gave up on parallel ports years ago and use a cheap usb to parallel cable.
Errm, it will have USB ports, they've not made one without since ... a couple of decades ago when USB took over from the 4 pin ADB ports and 8 pin serial ports. Other things are optional : the MacBook Air is designed specifically to be very small (thin) and very light - so loads of ports which need the machine to be "not thin" removed.My daughter was given a new macbook something for her work, and it is a beautiful thing to behold. I was comparing it with my asus windows one.
I asked her, does yours have a touch screen? No.
USB ports? No.
I began to think my£299 piece of crap wasn't so bad after all...but of course I'm an old git and just haven't got to grips with the mac thing...and I won't be trying to either.
Just the impact drill and TC tipped drills must have made a huge difference. Before my time, but I believe it used to be the apprentice's job to drill the holes when the new fangled Rawlplug "drill" (pointed chisel that you hammered and turned like a manual impact drill) came out.I tend to daydream alot when I'm working alone. I always end up thinking about how sparks in the past would be doing the same work in doing and how it may be more difficult. Power tools are such a big improvement. Drills, drivers, angle grinders, saws etc.... I job that I could do in 1 hour probably took 3 or 4 times as long to complete.
Aye....from nipping when your aim was failing and the chisel butt was giving.Yep I had to use a Rawltool quite a bit as a young apprentice, you end up with blistered hands.
Plasty in general I reckon was a game changerOh yes, has someone mentioned plastic plugs ?
I recall dad whittling bits of wood, and he had a tin of some white stuff that I believe contained asbestos, you mixed with water and stuffed into holes - then waited for it to set (?) before putting the screw in.
Don't think so, but then they have actually existed almost as long as motors have existed - just not in the modern, compact, electronic form. Actually, I suspect that variable speed drives of some form or other were more common before everything went AC - and then we had to wait for the development of power electronics to get back to where we were.Variable Speed Drives
Has anyone mentioned these yet?
Reply to Greatest Electrical Game Changers in the UK Electrical Forum area at ElectriciansForums.net
