Guest viewing is limited
T
Tasty
Hello for the second time today!I've been asked to install 2, 2 gang switches in a kitchen, which will switch the fixed appliances such as dishwasher etc. Now i've not used modular switches yet but from what I can make out they're pretty straight forward. My question is about integrating them into the kitchen ring, as I was planning on looping in & out much like a socket, then having the appliance wiring drop down from each switch, similar to a spur. However in order to have the switches on the ring, I'm assuming i'll have to bridge between the two individual switches inside each panel. Am I correct in this line of thinking? As always, any replies much appreciated! :) cheers
However, as you quite rightly say, there is no point in having two 13A fuses in series.
The done thing is usually to install them together with a fuse.
But you don't need a fuse. There's a fuse in the plug top. :banghead:
There's no difference between this and an unfused spur feeding a single outlet (perfectly acceptable) apart from the fact it is switched.
I know, and I quite agree.
All I'm pointing out, is that the done thing, is to either use an FCU, or a grid switch paired with a fuse.
To be honest with you, showing pictures of switches labeled with appliances doesn't actually mean much, as you can purchase FCUs with the same lables on Buy Crabtree Moulded Fused Connection Unit, Capital, Switched, Single Gang, DP, 13A, w/o Neon, /w Legend - 4827/WM.
Those are meant for direct connection of the appliance to the FCU (no socket outlet).
IMO the only reason for using FCUs with socket outlets is when it is feeding more than 1 outlet so as not to overload the cable.
Its the new damn thing to do now isnt it,all appliances switched from a grid,gud point bout the fuse,must admit sounds a bit odd,also r all switches rated at 32amps,mcb wud be 32amps.Maybe thats y radial circuits may b better than a ring then rated at 16/20 amps hav a gud rainy day ta ra bab
IMO if your going to the bother of grids above worktop Id feed to an unfused conection unit under and fit fuse module in the grid as this would save howking the appliance out if fuse goes or put the plugs in next cupboard to appliance for access
The switches are 20A. However the socket outlet they are feeding (single OR double) is rated at 13A so there's no problem. Think about a socket installed directly on the ring, they aren't rated at 32A are they.
Think of it this way. You can add 1 single or 1 double unfused spur off a ring circuit from a junction box. All you're doing in this case is replacing the junction box with a 20A switch and because the load will never be more than 13A, the 20A switch is more than adequate.
I had a job at the end of last year where I had to replace switches like this the originals were MEM (no longer made) so I had to replace them with MK but customer was not happy as the cost was not what he expected
This is really simple and the best way of switching appliances in modern kitchens nowadays. Leaves a neater job and saves having multiple switches around the kitchen. As Jud says linking through the switches and taking one spur down to either a single socket/fused outlet......its that simple. To the OP......a good tip is to use a deep backbox so you have plenty of room for terminating and making a neat job!
Cheers
Grid wiring in a kitchen ring
Australia
Tasty,
andrew692003,
