View the thread, titled "gu10 mains lamp blowing" which is posted in Australia on Electricians Forums.
J
james king
hi all i have changed 6x gu10 downlights in a kithchen as the down lights befor kept blowing there were LV.
what may cause the lamps to blow regualy eg only 3-4 hours of being on? all suggestions would be grat
Are you sure they are only lasting a few hours?...customers often say they have only lasted a short time when in reality they have got mixed up with what has been replaced. A loose connection serious to cause lamp failure would almost certainly produce noticable flickering.
I would still suggest it is lamps..(see robsparkys post)....try a different batch of a quality brand and get the customer to keep a plan of which lamps blow and when.
hi all just to let u no i have been back and its not the lamps. they are fine and so are the fittens.. who ever wired it befor have done some thing wrong.
i have 230V between L&N
230V between N&E
0V between L&E
230V between N&E
0V between L&E
Wrong polarity....the N and L are reversed......needs rectifying but wont affect lamp life.
Reply to the thread, titled "gu10 mains lamp blowing" which is posted in Australia on Electricians Forums.
