GU10 Question | Page 2 | on ElectriciansForums
Discuss GU10 Question in the UK Electrical Forum area at ElectriciansForums.net
J
Jamie Harris
Hi,
Apologies if this isn't the correct place to ask this. I had some builders in who I asked to change my old 12v MR16 with transformers to 240v GU10 LED lamps which no longer needed the transformer.
I didn't think anything was wrong until I had an electrician come and take a look at a different issue who told me that every light had been wired wrong and that I would need fire proof, earthed GU10 fittings.
He subsequently quoted me quite a large fee per light and I just wanted to make sure it was necessary before going ahead with it.
Could someone, either with experience or professional knowledge, tell me what exactly is and isn't necessary.
Do I need to change out every single fitting for one that is earthed?
Do I need to buy a fire proof cage for every single bulb as well? (I don't even think there is enough headroom between the upstairs floor and downstairs ceiling to be able to fit the fire proof ones).
Thanks,
Jamie
Polish builders :p
It's been just a year since the install was done, when I saw the way that he had patched the other lights to one light I was pretty shocked as well.
New electrician is quoting about ÂŁ15ish for each downlight that needs sorting, but like you said I think it's the way to go.
Polish Builders doing electrics :eek:
ÂŁ15 each supplied, installed & wiring rectified?
Edit : Did the electrician specify what down light he was supplying
Whilst I'm not an electrician, I work in the AV industry so have a working understanding of a few basic things. Is anyone at all able to recommend a DIY style solution which I could do myself to aleast make the house a little safer?
Thanks,
Jamie
Thanks,
Jamie
Nope, get a suitably qualified competent electrician :)
PS; I would get that ceiling skimmed as well, for a proper finish.
Reply to GU10 Question in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
CIS registration is pretty simple. Give the CIS helpline a call and request to be activated as a cis subcontractor. Not contractor though, there...
