GU10 Question | Page 3 | on ElectriciansForums
Discuss GU10 Question in the UK Electrical Forum area at ElectriciansForums.net
J
Jamie Harris
Hi,
Apologies if this isn't the correct place to ask this. I had some builders in who I asked to change my old 12v MR16 with transformers to 240v GU10 LED lamps which no longer needed the transformer.
I didn't think anything was wrong until I had an electrician come and take a look at a different issue who told me that every light had been wired wrong and that I would need fire proof, earthed GU10 fittings.
He subsequently quoted me quite a large fee per light and I just wanted to make sure it was necessary before going ahead with it.
Could someone, either with experience or professional knowledge, tell me what exactly is and isn't necessary.
Do I need to change out every single fitting for one that is earthed?
Do I need to buy a fire proof cage for every single bulb as well? (I don't even think there is enough headroom between the upstairs floor and downstairs ceiling to be able to fit the fire proof ones).
Thanks,
Jamie
http://i.Upload the image directly to the thread.com/YE0Q1vs.jpg
It's a detached house and they're in the ceiling, above it is the attic.
exactly what i'd expect from a builder/bathroom fitter/kitchen fitter. maximise profit by doing the job as cheap as possible as long as it works. those fittings would have come with an enclosed joint box. builder has discarded them to save time as they are quite fiddly to connect.
All the Polish builders I have encountered, who are not working for UK firms have little or no respect for any of the UK building regs.
As for changing MR16 to GU10 lamps, you need to ensure that that earth (cpc) is continuous from the fuseboard to the last fitting.......
A little off topic but most 'Polish' builders aren't even Polish :confused: and the ones I've met usually have better standards than most English builders, maybe I was just lucky though.
On topic,
I don't see any reason why they couldn't use choc boxes and get a better quality light fitting. Better still, just get LED lamps so there's little to no heat generated.
On topic,
Choc Boxes! where do you park your van:rage:
Reply to GU10 Question in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
CIS registration is pretty simple. Give the CIS helpline a call and request to be activated as a cis subcontractor. Not contractor though, there...
