Think I had better keep out above my pay grade
Way above my pay grade too Pete. Thats why I'm asking the questions. Half the trouble is that I want to have multiple points to hard wire in for internet connection but then theres all the other stuff you can do with home entertainment etc.
If you run 4xcat5e, 1x shotgun and 1 single coax to every tv position back to a central position then you are pretty future proof for whatever you want to install. 5 sat grade coax to dish position and 2 cat 5 low level external (if there is ever the chance of having virgin media).
If you want to hide sky boxes then think about positions and run a hdmi and IR extender to the TV.
If it's all back to a central position you've got the choice of installing a entertainment hub, hdmi matrix etc
Surely you mean Cat 6
CAT 5/6 vs satelite cables - https://www.avforums.com/threads/cat-5-6-vs-satelite-cables.2097207/#post-24967376
:rolleyes: Told you they were geeky!
the audio side is simple. big f*ck off sound system in living room.Pink Floyd on endless loop, leave the doors open.
When I did our refurb, where ever we wanted a TV, I ran 2 x satellite grade coax, 1 phone line and 1 x CAT5. Our BT line comes into a cupboard by our front door - 1 then ran a single CAT 5 into the loft above the cupboard where I planned to fit the switch - then I ran all the other points back to this - we now have 12 points around the house, plus a backup device attached to said switch.
With CAT5 you need to consider where the incoming broadband is, and where you want to place the switch.
The loft houses all the coax cables - only 8 points are currently connected and this can handle multiple inputs too.
Wifi, is there for the mobile devices.....
If you do something similar, I would recommend 47mm deep back boxes......
Best start writing a spec for each and every room and take it from there...
Ok I’ve already got 2 x CATS. Anyone recommend a good CAT flap. PS How do I wire in 2 x DOGS and 2x BUDGIES? :D
Network wise decide where you want to equipment to be located, router NAS etc etc then cascade down the house from there, mine is in the loft and I also have a patch panel under the stairs to switch things over if need be.
FatAlan
Trainee
Supporter
Surrey
Trainee Electrician
Guidance on home network wiring.
Computer and Networking Forum
FatAlan,
FatAlan,
