Had an electrician around to do an EICR but was given a quote for work instead. | Page 3 | on ElectriciansForums
Discuss Had an electrician around to do an EICR but was given a quote for work instead. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
True mate but then the op will probably end up being invoiced for it.
The OP invited an electrician to do an EICR - so at the very least, on receipt of the EICR and invoice the OP is obliged to pay him - if he doesn't pay the OP could end up in court.
OP did this guy just visually inspect the properties or did he actually test the circuits?
From what I could see this was a visual inspection but he did have a plug that lit up when put in sockets. I'm guessing this was a test of circuits of sorts! Also he checked how wiring was connected behind sockets and light fittings.
Ok if that is all he has done it is not enough to be considered an EICR. What he has done is a visual inspection, the plug that lit up basically on checks correct polarity of socket outlets.
as sintra says. plug in socket testers are only a first rough indicator. we usually let plumbers and BG use these to condemn perfectly good installations.
I think we are all thinking it but no1 has said it!!!! The report is BULL. Find outif he is NIC EIC registered If he is report him, to them. If not report him to the local council. Then come back on here and ask for a local spark in your area to come and have a look?? Im sure some1 will be willing to help? Then we can see a real sparks report.
For now name and location please? Name an shame is the best way forward for this foooooolllll!!!!!!
If the NICEIC find fault with th guy or he is not listed I think they have a wall of shame for unregistered pretenders using their logo for promotion of work.
It woul be interesting to see if the EICR is on a red, purple or green cert.
From what the OP has written he hasn't provided an EICR or even a VCR!
As everyone else has stated this cowboy is creating work for himself at your expense. Looks like you'll need a second EICR done, this time by somebody not wearing stetsons
cant see the problem myself - seems pretty standard
fail the installation - charge to put right
then do eicr and fail on other areas - charge to put right
follow up with eic and charge final bill.
pretty sure this is all covered in the competent persons scheme Electrical Trainee training course day 2.
Reply to Had an electrician around to do an EICR but was given a quote for work instead. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I think it is a good idea in general, it provides a form of proof that the landlord has provide access to the required documents. further to that...
Hello all easy cert users, ive been using easy cert since 2001 with no yearly subscription. and also found other people looking for older versions...
