Hard wired smokes with CU change? | on ElectriciansForums
Discuss Hard wired smokes with CU change? in the UK Electrical Forum area at ElectriciansForums.net
Manchester
Hopefully an easy one without much debate but I've just had spoke to someone who has had an electrician go to his rental property and say it needs a new CU which I'd agree, all sockets to be replaced as they don't have switches which I would personally but didn't think this was actually a requirement? But also a new circuit putting in for hard wired smoke alarms... now although I would recommend hard wired smoke alarms they aren't required following a CU upgrade are they? Re wires yes... new installations yes... id probably even push it if I was adding 1 or 2 circuits in but they have the required battery smoke alarms that the legislation for rental properties dictates that they must now have in place.
Anyone know these rules for sure? I was very confident in my response yesterday but the more I think about it the more I am doubting what I said and don't want to give him a bum steer
In England,
sockets do not need to be switched
hard wired smokes in your case would be recommended but not mandatory
scotland has different rules about fire detection though.
Easiest form of isolation is unplugging. Not handy if the socket is down behind a washing machine. Hence the need/want off an solar ion switch above worktop.
The age of unswitched sockets would be factor in whether they need changed or not, although I know you can buy unswitched sockets new.
It wasn‘t your autocorrect, I expect it was one of the mods just playing with you!!!
You can use the circuit breaker as an isolation switch so unless the consumer unit is not relatively easily accessible then even isolation switches above the worktop are not specifically required although it can be better to have them. (Personally I prefer the grid switches rather than loads of fcu's, alternatively put the socket behind the adjacent unit and drill a hole in the side of the unit so the power cable can be pulled through and plugged in..
It is required under Scottish building regs… that’s why I put “need/want” because sometimes easy isolation is required, sometimes not.
The trouble with unswitched sockets is people pulling the plug out on load. Which can happen if they leave the switch on anyway.
Totally agree, I have lost count at the amount of times I’ve been asked to check (dodgy) sockets due to the user plugging in equipment/appliances under load conditions and then sparking (arcing in our terms) I understand that by not having a switched socket doesn’t make a difference Aslong as the equipment is not on but by having a switched socket you can clearly see the socket in off position and no arcing whilst plugging in
But that doesn't make it a hard and fast requirement on an EICR
I have been in the trade for nigh on 40 years and can never recall suggesting plugging items under load into or from a socket has resulted in the socket becoming faulty, how have you verified this.
Reply to Hard wired smokes with CU change? in the UK Electrical Forum area at ElectriciansForums.net
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
