Harmonics distortion - power flickering | on ElectriciansForums
Discuss Harmonics distortion - power flickering in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Leb
hello team,
One year ago, I installed a solar PV system with batteries in my house. Whenever i start large loads, the inverter doesn't support the surges. At first, I thought the surges were very fast because i have HVAC VFD pumps (it's a villa). After one year, i suffered from the lights in my house that are flickering, and they have also experienced burnouts, as well as a damaged pump. as well the inverter is experiencing overload. I installed a power analyzer, and it turns out there are a lot of harmonics. I am now conducting research on this situation. What are your explanations for this issue?
[ElectriciansForums.net] Harmonics distortion - power flickering
Reply to Harmonics distortion - power flickering in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I am living in the north of Thailand outside of the big city. That means in the rainy season we have multiple times per week power outages...
Sorry, yes. I believe what he was surprised by was the absence of any voltage fluctuations while the A/C compressors were running. Unfortunately I...
Have I confused you or worse frightened you away? The tests I described may quickly decide your question.
Hi, Did this ever get resolved? I have basically the same issue, have contacted the DNO and I’m awaiting some power quality checks. Thanks
6K
Hello Marconi the sticker on the inverter says 06/2022 so I am guessing the cabinet was assembled in the October of 2022 when we received it...
2 3 4
17K
