have a look at this | Page 2 | on ElectriciansForums
Discuss have a look at this in the UK Electrical Forum area at ElectriciansForums.net
VoltzElectrical
Nearly Esteemed
[ElectriciansForums.net] have a look at this[ElectriciansForums.net] have a look at this
I have been asked to rewire this foreign bought lamp, or at least assess it for the safe possibility of doing so.
Now it was supplied with a two pin plug and flex and the lampholder is plastic. The metal body is obviously unearthed.
I was going to re flex it in 3 core and earth the body, but on closer inspection the contacts look dangerous to me.
I can fit my pinky finger down in there and touch the live terminal.
My opinion is leave the thing unflexed and let them use it as an ornament only as to me it's as bad a reversed polarity on a metal edison screw lampholder. (which by the way the father of the owner has recently had a belt off I have just found out so I will be looking to go over and fix that too!)
Cheers.
Voltz doesnt usually come across as stupid but this topic really is retarded.
every bloody table lamp in existance has exposed lampholder pins.
the usual guidance is not to stick your finger in there unless you want to be a candidate for the darwin evolution award.
C'mon voltz , wake up.
i only had in mind that E/s fitting lampholders had to have the line connected to the pin, not the screw, therefore, by omission, that the pin was deemed to be inaccessible. Hence my post.
come on voltz...
dont be like that...
i thought you were supposed to be an educated man...ex-teacher n all that lot...
were only having a little dig..
but you have to admit...its a totally thick thread isn`t it...
cheers Glenn, but I don't need a dig, I was just after a little advice about something I haven't come across before.
I guess that was too much to ask...
Reply to have a look at this in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the input guys. Lighting track is out of the question. The routing (h section guirders and angle iron) means that swa cable clipped...
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
Recommended Sponsor News
Hi everyone,
