Discuss Headlights On With Lock/Unlock, Welcome/Leave Home in the Auto Electrician Forum area at ElectriciansForums.net
Hey all,
I am trying to set up a module that i can use to turn on headlights with lock and unlock so basically I have all things sorted out except one thing. I want the module to stop working if my headlight switch is set to the OFF position, so basically my switch gives negative ground to 1 of the wires when its set to OFF and i wanna use that signal to turn off the module but i cannot figure that out. I can do that with 5 pin relay but that would mean the relay will stay energised and will drain the battery. Does anyone know any other way? Like a transistor or something?
Thanks in advance
Reply to Headlights On With Lock/Unlock, Welcome/Leave Home in the Auto Electrician Forum area at ElectriciansForums.net
Hey Guys. I recently flooded my 1999 Toyota Hilux in a river and I have been having issues with my central locking. I can unlock all of the doors...
Im making this cct for fun. Ive seen it in a video on youtube, with different IC's. So I decided to adapt the cct to what IC's I already have. And...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Hi everyone I don't know this is the right place to ask but i just wired up a gm 4 (also known as zke iv) for my bmw e36 from 1996. So the problem...
Hi all. I'm trying to put a light-bar on my (facelifted) Land Rover Freelander 2. I'm wanting to wire it so the light-bar will be energised when I...
